2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Will not boot up, completely dead
Hello,
Bought as non working with broken screen and would like to repair. When charger is connected I get a green light and then orange as the battery is charging. Try to start but only get power to the hard drive which spins up and keeps spinning (no lights or other activity no power to keyboard. When trying to start with just battery the hard drive spins up for 5 seconds and then stops. No signs of liquid damage or major impact damage. Have re-seated each connector on logic board one at a time and tried to start but get the same.
Am open to try anything as I've nothing to loose,
thanks
Score -1
Add a comment
Chosen Solution
A lot of unknowns here. Try hooking it up in Target Mode via a firewire cable to another Mac. Start your machine up holding the key down. Run Disk Utilities from the other machine. You may have to install a system. Next hook it up to an external monitor and see what you get. Let us know your results and we can proceed.
Score 2
3 Comments:
I'm unable to hook it up to another Mac but there is no output to an external monitor.
by
just noticed as well that there is a faint ticking coming from the left i/o board area when the magsafe is plugged in
by
also !! there a a chip (isl9504, pwm controller ?) that is getting very hot within seconds of hitting the power button
by
Add a comment
I have a macbook pro mid 2009 17 inch that does about the same thing, and I noticed my isl9504 appears to be burnt out completely!
Add a comment
Add your answer
Ben will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,649
