after running 2 minutes in heat cycles only stops can be started up
G.E. DRYER MOD. DCVH680EJ1MS stops after running 2 minutes in heat cycles only ,but can be started back up only to stop after another 2 minutes. Dryer will run fine in non heat cycles.What's up with that?
Thanks,
Jim
3 Comments
Does the drum rotate fine? Are there any abnormal sounds? If it seems to be working fine mechanically, look into checking the heating element or control panel. Usually if the heating element fails, the dryer will keep working and your clothes will just not be dry when the cycle completes. Try watching some repair videos for your model dryer on appliancepartpros.com or repairclinic.com
by Anthony Kouttron
Shut down? My ge profile dryer does not shut down but pauses mid cycle. Any thoughts?
by Mark Narvaez
Hi @Mark Narvaez,
What is the model number of the dryer?
Does it do this on all drying cycle options?
Does it start up again after the pause interval? If so is the length of the pause the same every time?
by jayeff
