Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3531 Questions View all
iPhone doesn't chage after screen replacement
i replaced the screen. iPhone is working fine but phone doesn't charge even after keeping it connected to the charger.
It is loosing the charge instead.
I checked charging port flex and changed the battery too. None of the troubleshooting worked.
Score 1
Add a comment
1 Answer
try to change the charging port,if doesn't work maybe during your screen replacement you accidentally damaged you motherboard and cause short circuit,try to find the charging circuit and check the circuit
1 Comment:
I already checked the charging port. It didn't solve the issue.
Is there any way to check the charging port circuit and fix if that's the issue?
I would appreciate if there is any guide to do it.
by
Add a comment
Add your answer
acc asd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 35
