The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3763 Questions View all
Microphone is not working.
Hello,
I do have a IPhone5s were the Microphone ist not working (in normal mode), when I use the loudspeaker function it is working well.
I already changed:
-Lightning connector
- iPhone 5s Front Camera and Sensor Cable
- the Logic Board
- and the loudspeaker (just in case)
But the problem ist still there. When I do a call the oposit doesn't hear me. When I then hit the loudspeaking button, they hear me.
May someone had the same Problem ?? Thanks
Add a comment
Chosen Solution
make sure the front camera is installed correctly, make sure the mesh by camera is clean, make sure the mike on the sensor is aligned correctly.
Score 2
Comments:
I cleaned the mesh by the camera and the mesh by the mike. This did it! Thanks a lot.
by
I am glad it worked.
by
Add a comment
If the front camera is not clicked in and installed properly into the housing area, it will not pick up anything.
Add a comment
Add your answer
Jens Naffziger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 94
