Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2688 Questions View all
6s battery replacement wont rise above 20%
just replaced my battery with a new one from I fixit and I waited until battery went below 9% now i've been charging for 2 hrs and it will not go above 20% charge
I know its charging because I see the lighting bolt in corner but it wont raise above 20% can somebody let me know if thus is normal
thanks
Add a comment
1 Answer
Chosen Solution
No it is not normal...
Your phone is suffering from fake charging. Do you have access to a USB Ammeter? That would answer your question definitively of wether the phone is drawing current or not (hence charging).
I presume you changed your battery because it was not charging or holding a charge. Were you aware that Apple has a "recall" for the iPhone 6S in regards to battery issues? Check out the website to see if your phone is eligible for a free battery replacement.
If the problem is fake charging or Apple will not do anything, then your phone will require a micro-soldering repair.
Score 1
Add a comment
Add your answer
JOSEPH BERENATO will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 68
