Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
876 Questions View all
iPhone 7 screen flickering
Hello, I have an iPhone 7 screen was cracked and replaced and now the screen flickers. What causes this and how would I fix it? I also have an iPhone 6S plus that does the same.
Score 1
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
Does the original screen flicker if you re-install it?
Screen flicker is usually caused by improperly seated or dirty connectors. Take a closer look, under magnification to see if there is any debris impeding a good electrical contact. You can also clean both sides (flex & logic board) of the connector with IPA (>90%). Sometimes, the retaining bracket has to be installed completely before flicker goes away.
Score 1
Comments:
That looks like a defective screen. Do the IP7 and IP6S do exactly the same thing? If so, you may want to consider changing suppliers.
by
Add a comment
Along with the flickering, it turns colors sometimes. It seems like certain colors triggers it. What do you think it would be? Maybe a cheap screen that was used?
Add a comment
Add your answer
CAB will be eternally grateful.
Past 24 Hours: 10
Past 7 Days: 78
Past 30 Days: 316
All Time: 15,518
