Announced on September 9, 2015, the iPad Mini 4 maintains the power of an iPad Air 2 in a smaller form factor.
174 Questions View all
Where can you buy a replacement ic chip cable that is on the digitizer
I am looking to purchase the ic chip cable that is attached to the digitizer \ LCD assembly. What is the correct name on the part and can you purchase it? It is located to the left of the home button assembly. This is for the iPad mini 4.
Add a comment
1 Answer
Chosen Solution
I presume you mean the sensor for the Smart Cover...
Normally you de-solder it from the original digitizer and transfer it to the replacement. I don't know if it is sold separately but do a Google search for "ipad mini 4 smart cover sensor"
According to iFixit:
Please Note: You will need to swap the sensor flex cable assembly from your original front panel. This procedure requires micro soldering and board level repair skills. If you don’t know what this means you may not have the knowledge or tools to install this part. If you’re curious and want to know more about getting into micro soldering, here’s some good reading and some good watching to get you started.
iPad mini 4 Screen Image
Product
iPad mini 4 Screen
$159.99
Score 1
Add a comment
Add your answer
Chris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 460
