Why is red power light blinking?
Red power light just started blinking, have plugged into wall most of the time, never lose charge. What does it mean?
I believe that the blinking red light indicates a failing battery or power adapter, if I recall correctly from a past repair. Sorry that I can't be more informative, I haven't had the opportunity to work on many Asus notebooks.
How can I fix it?
@madalitsokhuvulo
What is the model number of the laptop?
Create a Win 10 battery report and check on the status of the battery.
Have you checked that the charger is OK by trying another compatible charger or measuring the charger's output at the plug that plugs into the laptop?
Past 24 Hours: 10
Past 7 Days: 57
Past 30 Days: 234
All Time: 16,579
2 Comments
I have the same problem but my Asus is only 2 years old, how can the battery already
fail
by madalitsokhuvulo
In my case, a K52F from around 2013, it turned out the detachable battery had gotten a bit loose
by Jules van Laar
