Ordered Verizon specific charge port, phone will not recognize
Ordered G5 battery port specific to phone.
Phone give message: "the module you've attached doesn't work with this phone or isn't inserted correctly. Please use a Verizon-compatible module..."
Score 2
Add a comment
Where did you order from?
These things are easily mixed up.
I suggest speaking with the seller to get a return or exchange.
1 Comment:
I bought a charging port assembly from iFixit and got the same message.
by
Add a comment
I bought a charging port from a different supplier, installed it and got this message. Put the original back it - works.
Update (07/07/2020)
It was most definitely a bad part, FYI! Problem solved with a charging port bought from a different supplier.
I had tried 2 different ones from same supplier and had same issue. They must’ve had a bad batch.
A good reminder to think about the parts you’re using, it could always be that!
Add a comment
Add your answer
vanceakins75 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 400
