Fisher & Paykel IW812 - hot and cold water not filling?
Machine will not fill automatically when hoses are connected via the valves.
When machine is turned on, can hear the hot and cold valves turning on momentarily allowing a trickle of water to enter the bowl then no water flows.
Removed both hoses from the inlet valves and confirmed good flow is present (Currently filling the machine manually thru the filling cycles via the hoses to complete washing and machine works fine).
With hoses connected to the inlet valves, set machine to cold fill, auto water level and turned on cold tap only and started machine. No cold water flow. Turned off cold water, set machine to hot fill, auto water level and turn on hot tap only and restarted machine. Hot water filled for about a minute then machine went into water recycle mode and hot water did not flow from that point with machine staying in recycle water mode.
Hope you assist and provide advice.
Thanks
