F2 Error displayed. No clogs, drains very well, drain pump won't stop.
My washer has been displaying the F2 error. I found the manual and looked through the relevant post about this error but my washer drains very well. The problem is the drain pump won't stop running and I get the F2 error after 8 minutes. Is there a sensor that tells the pump to stop after draining is complete?
The toubleshooting guide I found inside the washer says check the filter, check the lines for clogs, check for obstruction on pump motor, then, if all those are good, replace the motor. All of those are good and the motor is good as well.
Any help is appreciated.
