Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
3932 Questions View all
My iPhone 6 has no signal! I need help.
Hello! I have just replaced my iphones screen with the Wifi Antenna and the Flex cable so it can gain back some wifi. But after everything was fixed. I turned it out and my phone can't connect to my carrier. I need help on what part to replace. The wifi seems to work fine, it's just the signal to my carrier. Thanks in advance! Just need help on what went wrong here.
Update (07/11/2017)
Not working, I have already tried everything! Which includes resetting it, switching sims cards, check if all parts are installed correctly.
Update (07/12/2017)
Still not working. Tried the IMEI thing too.
Comments:
Sometimes going in and out of airplane mode will fix it in software
by
Add a comment
1 Answer
Chosen Solution
Check if the IMEI number is displayed via *#06#.
Score 2
Comments:
The call fails :(
by
It's supposed to display IMEI not initiate a call.
Did you make sure you typed it correctly?
by
Hello yes it displays an IMEI number?
by
As far as I know the 3G antenna cable is connected to the charging port assembly.
Also damaged housing especially at the top or bottom can cause antenna issues as parts of the iPhone housing acts as an antenna.
by
Add a comment
Add your answer
Jasman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 75
