White line unresponsive screen
I dropped my I pod now it has a white line down the left side of the screen and the keypad is unresponsive. How can I fix this?
Anyone trying to answer this will likely need some additional details. Can you include the model of the iPod?
From your description, it sounds like an iPod Touch. I am going to assume this to be correct. You've likely damaged the digitizer, which is what responds to your finger when you touch the iPod. If that is the case, you'll need to replace the digitizer. The fact that you have a white line on the display means you've likely damaged that as well, and will need to replace that at the same time.
Once you know the model, you'll most likely find a walkthrough for replacing the affected parts on this site, and probably the parts for the repair, if you need them.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 44
