Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
272 Questions View all
No video (black screen) upon boot, is it my logic board?
Thanks to the excellent info on this site I have tried the following things that all result in the startup chime, but no video:
  • Start from intall disk, holding down C
  • Start from install disk, holding down D (hardware test)
  • Reset PRAM w CMD+OPT+P+R
  • Change RAM to known good RAM
  • Using known good RAM test each RAM slot independently
I was also able to access the hard drive just fine after booting into firewire target disk mode (holding down T)
I will need to buy an adapter and borrow a friends monitor to test the external display. If I do so, what is the value of this test? Determining if it's the LCD itself vs. the logic board?
I no longer need this computer but I want to either fix it myself (I am capable of an easy or moderately difficult repair) or accurately describe the issue if I sell it as-is.
Thanks in advance!
Caitlin
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
If the external works then your GPU (graphic processor unit) is fine.
Score 2
Add a comment
Add your answer
Caitlin Dean will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,911
