Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2689 Questions View all
Caller can't hear me after port change
I've changed the charging port on a 6s and when I checked it everything was working as it should, now the mic has stopped working on calls. I can be heard when in loud speaker and hands free only, there was a metal shim on the mic at the right of the port that I couldn't get off the old one so I hadn't replaced it. Could this be causing the issue?
Add a comment
1 Answer
Chosen Solution
I recommend testing the charging ports before install, most functionality coming from it if possible.
Sounds like a faulty charging port (main microphones on the port not working). I suppose it could of went faulty from being improperly installed (tear in ribbon cable / puncture).
I have replaced them before, but not really sure what metal shim you are referring to.
Are you referring to this in step 46:
iPhone 6s Lightning Connector Assembly Replacement
There is black tape covering a screw hole for a metal cover for an antenna cable.
Score 1
1 Comment:
Hi, thanks for your response. I've done loads of charging ports and never had an issue before, if you look at step 55 there is a spudger on the mic with the metal shim which was missing on my replacement charging port.
by
Add a comment
Add your answer
S2i will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 530
