Why is it skiping songs without touching anything?
can this problem be fixed?
Try to setting it back to factory defaults with iTunes.
How to restore iPod
1. Verify that you have an active Internet connection, because you may need to download new versions of the iTunes and iPod Software.
2. Download and install the latest version of iTunes if necessary.
3. Open iTunes. Connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
4. After a few moments, your iPod will appear in the Source panel in iTunes.
5. Select your iPod in the Source panel. You will see information about your iPod appear in the Summary tab of the main iTunes window.
6. Click Restore.
7. If you are using a Mac, you will be asked to enter an administrator’s name and password.
8. A progress bar will appear on the computer screen, indicating that stage one of the restore process has begun. When this stage is done, iTunes will present one of two messages with instructions specific to the iPod model you are restoring.
9. During stage two of the restore process, the iPod displays an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remain connected to the computer or iPod power adapter during this stage.
Note: The progress bar may be difficult to see, because the backlight on the iPod display may be off.
10. After stage two of the restore process is complete, the iTunes Setup Assistant window will appear. It will ask you to name your iPod and choose your syncing preferences, as it did when you connected your iPod for the first time. Remember that this will ERASE all your files on the iPod of course all of this is available on http://support.apple.com/kb/HT1339.....g... luck
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 754
1 Comment
Did anything happen to the iPod? Did you drop it, fall, water damage? Anything? IS this something that has just started? Any other symptoms? More info will help to get it fixed :) thanks.
by oldturkey03
