Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone stuck on activation screen and is only saying 'NO SIM'
hi , im really stuck as my phone is stuck on activation screen and although thers a sim card inside the phone it just reads 'NO SIM' . i need help as i cant activate the phone and it just wont pick up the sim card. Is there any way that i could activate the phone using a third party app or anything ?
will appreciate any help
Score 1
Add a comment
1 Answer
Chosen Solution
Please insure that your SIM card is oriented and installed properly. I know it sounds like a dumb suggestion but this stuff does happen. It is also possible that your SIM card is simply defective; can you try someone else's SIM card to eliminate that possibility? If a known-good SIM card (appropriate for your phone as it may be carrier locked) doesn't work, then...
This brings me to the third option and that is it could be the SIM Card Reader which is defective. It is possible that one of the internal pins is bent or shorting to an adjacent pin. You could open up the phone to take a look. Follow this guide. If it is just a bent pin, you should be able to fix that. If the pin is broken, then that will require a micro-soldering repair.
Score 1
Add a comment
Add your answer
Usaamah Vally will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 782
