Released by Samsung in March 2016. Model SM-G930.
425 Questions View all
Cracked screen, blurry photos on front camera
Hello everyone, I dropped my S7 on asphalt and cracked the screen. It still works perfectly except the fact that the front camera takes blurry photos...light seems to be seeping in through the cracks and thus makes the photos look too bright and sort of whitewashed. So I was thinking that maybe it's better if I just take off the cracked parts in front of the front camera.. or is that a bad idea? Thanks!
Add a comment
Chosen Solution
Sadly, you should remove the glass, but you can't simply remove the glass with high risk of damaging the LCD. You best replace the whole display assembly.
Score 1
Add a comment
Most Helpful Answer
I did that and it made it far worse....dont!
Score 1
Add a comment
You'd better replace a new screen, the display is easy to damage without glass.
Add a comment
I would not recommend taking off the glass it could be dangerous and make permanent damage to the phone I would rather replace my phone
Add a comment
Do it that always helps ngl but you gotta be carful when doing it have your camera on when you do it so you see when it’s not blurry
Don’t get water in your phone
Or any liquid at that
Add a comment
Add your answer
Czarina Del Rosario will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 18
All Time: 7,526
