Repair guides and support for Saturn's 2nd generation SC, SL, and SW.
15 Questions View all
I have no low beams,
I have checked the fuses and replace all four headlight bulbs
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
skipkuchta, Recheck bulb sockets/wires/plugs/etc. for corrosion, clean if needed, reseat bulbs and try. Check all ground wiring in vicinity of lighting circuit, check for damage, clean connections and retighten. all looks good and still no go, possibly a bad headlight switch. Check the link below to possibly solve your low beam issue. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.justanswer.com/saturn/2yg84-9...
Score 4
Comments:
@lpfaff1 We need you on meta.
by
Add a comment
skipkuchta besides the excellent answer provided by my esteemed colleague, you also want to check the relay. From the diagram it looks like the Saturn share the Fog lamp relay with the driving light. It is located in the under the hood junction block.
Score 3
Add a comment
Add your answer
skipkuchta will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 84
