I believe the Hard Drive Cable is bad, it won't format, boot,
I cloned the old hard drive after placing it in a case and using it as an external drive.....so that I could increase to a 1T storage space, but I have not been able to boot from the new cloned drive...it was reformatted and partitioned according to CCC instructions.
Now, I want to reformat/erase the drive, but I can't get it to erase/unmount, or anything. Can you help??
Update (06/27/2017)
The Macbook Pro is mid 2009, I can't find a model # in About this Mac
The Hard drive is HGST 1T, I did try to erase it in disk utility, it said not successful.
The Mac will not connect to my WiFi at this time, so I can't plug it in to EveryMac Lookup.... When I click on my WiFi, the box for password doesn't even appear. This has never happened before, so I figure my unsuccessful attempt to erase the mounted internal HD has messed that up. I am booting from TM backup. Main thing I need is to get back online, now, or I won't be able to fix anything. I connect using a hotspot, and it's never failed me before.
4 Comments
Can you tell us what your exact model is as well as what hard drive you bought. There are a few possible issues here besides a bad SATA cable.
To help you identify your system you can go to this web site: EveryMac - Lookup and plug your systems S/N in. Once you have your models info paste the URL here for us to see.
by Dan
had you used disk utility to erase?
any error messages?
by Augustine
The serial number is on the back of the machine in fine print.
by mayer
Your systems specs: MacBook Pro 15" 3.06 GHz Core 2 Duo (Mid 2009)
Your HGST HDD specs: Travelstar 7K1000 Series HD's
by Dan
