Shortened battery life, white spot on screen
Hello, my phone (iPhone se) got wet about two weeks ago. It was in a waterproof case that didn't work. Not knowing any better, I tried turning it on several times right after which didn't work. After letting it dry in front of a fan for 3 days it still wouldn't turn on. I tried charging it which didn't do anything. I came on this website and ordered a replacement battery and also cleaned the logic board with alcohol. I was amazed when it turned on. There was very slight corrosion where the battery connects to the logic board. My main concern was getting my data back that I didn't back up. I was able to do so and am happy. The phone is working normally, but has a shortened battery life. Less than a day just sitting and not using it. It seems to get warmer than before. It also has a white spot on the screen that you can only see when looking at something with a light backgrounds. Any ideas if these issues are fixable or what might be happening? Thanks.
