How do I repair a cracked display?
Have an iMac with a cracked display. I can't feel any crack or unevenness on the screen but when I tap it, the screen jumps. Any help will be appreciated. Pics are attached.
Thanks
Update (06/23/2017)
Update (06/23/2017)
Here is what I have.
6 Comments
@ramadi you did not attach any pictures. To do that use this guide Adding images to an existing question You also want to properly identify which 2011 iMac this is.
by
pictures added.
by
2011 iMac. Thanks for any help
by
@ramadi looks like a 20inch. do you have a serial number or an EMC number? check on here https://support.apple.com/en-us/HT201634 to properly identify it, the serial number is on the underside of the base (or foot) of the iMac, along with a bar code and regulatory markings.
by
Thank you for all the assistance.
by
Show 1 more comment
Add a comment
1 Answer
Chosen Solution
@ramadi that is a broken LCD. The only way to repair it, is by replacing it. Since you did not tell us which model iMac this is, start here to determine which guide you need.
Score 2
Add a comment
Add your answer
TPowers will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 75
