Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1498 Questions View all
how do I disconnect the ribbon with the spudger?
I have pulled up the front panel and am using the spudger, to disconnect the ribbon, but I am not sure how to disconnect. It has a spongy sticky pad on it am I supposed to pry it up or something?
Add a comment
1 Answer
Chosen Solution
The key with these connectors, is to pull straight up (if you are talking about the one for the digitalizer/display assembly) if you use minimal force, while doing this, you won't damage anything, use the spudger to gently pry up on each side of the connector head until it's free, i accidently broke a few cables like this, on my Powerbook G4, and have seemed to have perfected the removal method, just remember, nice and slow, and use no excessive force. With stuff like this, excessive force required useally means you are doing something wrong!
Add a comment
Add your answer
kimp803 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 932
