Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3267 Questions View all
iPhone 5 water damge
my phone was in sea for 5 sec
when i catch first was on after one 1 min he turned off
i have opened and remove the EMI shields from the board and then i cleaned whith alchole water damge
but the phone doesn t turn on
what to do
Add a comment
1 Answer
Chosen Solution
Congratulations for not putting it in rice and actually trying to displace the water with alcohol (IPA)!
Unfortunately, if the phone did not turn on after you did a decent DIY cleanup, then there is probably water underneath some of the IC's (causing shorts) or some components may have failed. Plus salty water is the worst kind of water for your phone to fall in. At this point, if you want to recover data (or attempt to fix the phone, which is not always viable), your only real option is to have it looked by an experienced repair shop that specializes in water damage repairs.
Score 2
Comments:
after cleaned the phone turned on
for 5 sec only at the apple logo
than it turn off
i tyr to turn on again but no result
by
Add a comment
Add your answer
keidi.bilali will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 51
