Where is the fan switch on the head located for a 2000 Honda Accord e
I can't locate the fan cooling switch that's located on the head for
My 2000 Honda Accord ex
@sis, Lori, Found this info. from the link below. The electric cooling fan switch is installed into a coolant passage of the engine near the thermostat housing and operates the radiator electric cooling fans when the coolant temperature reaches a specified temperature. Locate the cooling fan switch near the thermostat housing on the left side of engine behind the distributor assembly. The switch wire colors should be green and black.
Some models have two electric cooling fan switches, switch A and switch B.
Locate the cooling fan switch near the thermostat housing as follows:
Switch A: Left side of engine behind the distributor assembly, facing up. The switch wire colors are green and black.
Switch B: Left side of engine behind the distributor assembly, facing the firewall. The switch wire colors are white/green and black.
2nd link from Accord forum may also help in locations and diagnosing. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
On my 99 accord 4cyl. I found a piece of wire stuffed in the plug when i was cleaning all the plugs in engine bay..
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 41
All Time: 13,291
