Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
4035 Questions View all
Screen replaced and responsive for a min then becomes unresponsive. Wh
So I replaced the screen for a friend here and after replacing it, it works for the first few minutes of bieng on well and then after those few minutes becomes completely un responsive. What's going on? I checked all connectors twice, and I checked for tension on LCD but it wouldn't work right after restarting if it was tension. Help!
Comments:
Is it the issue where the screen does not turn on sometimes (Usually 50% of the time)?
Usually this is a defective aftermarket replacement screen and in most cases another replacement screen will fix it.
If it is what I think it is with the screen not wanting to turn on 50% of the time it's a PITA to test before install as it sometimes takes like 5 minutes to even find that the replacement screen has that issue.
Are you refering to touch screen or image / screen display issue?
by
I bought a screen from here on ifixit so it was a quality screen
by
Well the crucial question is it that the screen is totally dead? or is it touch stopped working?
Defective screens are a possibly. I would contact iFixit about this issue.
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
My first suspicion would be a poor quality replacement screen. Where did you (or your friend) buy it from?
You always have to isolate some variables and here you have a problem in not knowing if you did something wrong, broke something while repairing or have a bad part.
I would re-install the original screen (I'm assuming it was just cracked). If the original screen works then you have a bad screen. If it does the same thing, then you messed something up and you will either have to continue troubleshooting or bring it to a shop that has parts on hand to find the problem.
Score 4
Comments:
I bought it from I fix it so I would assume it's a good quality screen and the original screen had crack and holes in it. She ran the screen til it died then came to replace it
by
Add a comment
Add your answer
Michael Ocasio will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 47
