Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Questions View all
Will not charge, no charging light on magsafe?
Hi, I plugged my MacBook into a friends aftermarket power supply, and when i returned home there is no light when plugging it onto a real magsafe charger. Tried using a different charger, resetting SMC.
Also if I plug the magsafe into a different mac and then into mine, the light is orange but slowly goes dimmer until it goes out, and doesn't charge the mac.
Add a comment
1 Answer
I was having that problem. I had several after market power supplies an very slowly my MacBook Pro stopped charging. I would wiggle the MagSafe a little and the amber light would come on the start charging but it got worse and finally I decided to change out the upper case. I SO didn’t want to pull my Mac apart but I finally did.
Do you know what fixed the issue?? A half hour replacement of the MagSafe DC in Board part. I bought a used one off of Ebay for $8 and used the iFixit Guide and it was all better. The amber light came back on with ALL the after market power supplies I owned. I was SO thankful. Try it. You will see
Add a comment
Add your answer
Chris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,267
