The 8th and final generation of the Eldorado.
30 Questions View all
Gas is leaking out of my muffler when I start it.
Gas is leaking out of my muffler when i start it.
Comments:
Are you sure its gas and not just condensed water?
by
Add a comment
1 Answer
Chosen Solution
You need to run the vehicle long enough to let the pipe get hot, which stops the production of condensation. When the exhaust is hotter then the inside surface of your exhaust system, you produce condensation. That causes condensation everytime you start up the vehicle, in cold weather, you produce more. If you run the engine long enough, it will empty the water from the low lying areas, which is why you should not just jump into your vehicle in the winter, drive 1 mile and stop it. That will rust out your exhaust quickly. In the summer, you produce less condensation because the pipe and the exhaust stay at a closer temperature which produces less condensation.
Score 3
Add a comment
Add your answer
anthony will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,403
