I ran out if gas and bow I can't get it started after putting gas in it
I tried to start it 3 or 4 times before putting gas in it I put two gallons in it and now it will turn over but it will not fire a disconnected a fuel line and turn the key forward and it sprayed gas so the pump is still good and when I put carburetor cleaner in the air filter open it up it backfires but that's the only thing I can get it to do I also reset the inertia switch.
Score
0
I think there's some air in the loop. I don't know how to fix this but maybe you can find it online?
by Max Tech
Can I feather the throttle cable under the hood to work it out or do I have to keep turning the key back and forth?
by Thumper Evans
Can't tell you, Have you contacted a specialist? He might be able to help you out better than I do.
by Max Tech
check to see if you have a good spark at the plugs, Chris.
by chris
