Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
853 Questions View all
Which 80 GB HDD for a 30 GB iPod
Hello,
I am refurbishing my iPod Video 5th Generation Late 2006 and I am looking for a 80 GB HDD that fits into the 30 GB rear panel. I know from previous posts that Samsung has a 120 GB HDD that fits, but I don't need anything that large.
I did some research on the internet, but came out empty-handed and extremly confused. I am fairly new at this.
Any suggestions?
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
@sopholiver this drive :
Manufacturer: Toshiba
Model #: MK8022GAA
Capacity: 80 GB Unformatted
Dimensions: 1.8" wide x 5mm tall
Speed: 4200 RPM
Buffer Size: 2 MB
should fit your iPod video without any issues. Make sure that you measure the thickness. The iPod Video uses a slim drive. If you cannot find one with the same thinness as your iPod you can get a slightly thicker one. For that you will require a few other parts as well. The iPod 5th gen 60/80 GB are thicker drives. You will require a deeper rear panel, a new head phone jack since the cable has to be longer as well as a new battery for the same reason You will also need the rubber bumpers from the bigger drive as well. Not an outrageous cost for a pretty straight forward swap.
Score 3
Comments:
Thank you so very much.
by
Add a comment
Add your answer
Sophie Oliver will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 17
