Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 won't turn on after sensor flex replacement
HI ,
recently i changed my sensor flex cable because my old sensor was not working .
unfortunately i forget to remove the power cable before disassembling .
now my iPhone won't turn on .. not taking charging and even not detected by iTunes .
anyone can help me out .
thanks in advance .
7 Comments
Does it works ? :) Enjoy your phone :) im happy that it helps you :)
by
Did you plugged it in with your cable ?
by
hi .. still same .. won't on :(
by
Try charging it if it will work ?
by
yes it was plugged in with my own cable ... but not with charger with my laptop only .
by
Show 2 more comments
Add a comment
Chosen Solution
Just unplug the battery return it back on your phone is okay for sure :)
3 Comments:
Hi ,
thanks for the reply .
did the same but no luck .. any other idea ?
by
Maybe its a battery problem already bro .You damaged your battery .
by
hi ,
battery is new .. i mean phone is only two months old .
sensor replacement can damage battery ??
by
Add a comment
Most Helpful Answer
What do you mean by sensor replacement? Is that the front camera ribbon cable flex assembly?
Did you try booting up the phone with front camera flex and home button extension cable unplugged from logic board?
Have you made sure not to put the longer screws into the 3 screw holes on the board to avoid long screw damage?
Score 2
1 Comment:
Hi Ben
Yes it was sensor flex cable with front camera.
I tried booting up after assembling everything on logic board.
& I am 200% sure it was not longer screw damage because i tried booting without that plate and screw.
Tried with new battery and new sceen but no luck ...
Do you have any other idea .. thanks
by
Add a comment
Add your answer
vinod will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 116
