Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
error 9 and 14, related to screen fix?
I changed my screen on iphone 6 plus, because it cracked once.
Updated to IOS 10 (like 4 months ago)
since then continuously get error 9, 14, and 2009
tried to fix at store , they swapped ic flash power but still iphone crashes
may the error be related to (probably non genuine) screen replacement?
Can't update or restore at all...
Update (06/12/2017)
Hi ben, thanks for the more detailed answer... so what to do , should i attempt to fix it myself, and loosen up the screws?
thanks...
Add a comment
Chosen Solution
It's probably long screw damage from putting too long screws or overtightening the screw holes on the board.
The screw holes in particular are the 3 out of the 5 lower screw holes for the metal cover that goes over the screen connectors on the logic board.
This is hard to spot without a microscope in the screw holes.
Score 2
2 Comments:
so what to do? should i loosen the screws? thanks for the answer....
by
Loosening the screws won't help. If this is the case you will need to take it to someone that does micro soldering to fix the long screw damage on the board.
by
Add a comment
Most Helpful Answer
Board issue, you need to find someone with board repair skills.
Score 2
Add a comment
Add your answer
Stephan Georgi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 353
