Repair guides for a large selection of Panasonic digital cameras.
346 Questions View all
LCD screen is black replaced it and still has no picture
Hi there everyone
I have just got a Panasonic lumix LX3 camera
But like the rest of you on here the camera all works but the LCD screen is black
Can not see anything
So I thought I might as well try and fix it brought a new screen took the old one out and put the new one in hay presto guess what it still has no picture so what now
Can anyone help me please
Kind regards
Update (06/11/2017)
Hi there again I have checked the FP9004 COMPONENT
Using the meter and it measures 2.4v
So there is power going to the back light
Also I tested using a torch on the LCD screen but still nothing
No menu still can see nothing
Any other results
Hope to hear from you soon
Kind regards
3 Comments
@dimbie It still takes the pictures okay and no other issues but the LCD not working?
by
Yes the camera still take pictures and all other settings are working as they should just no screen or light even though there is voltage going through
Kind regards
by
mine is like this black screen will take photo ok but i can not see how to focus on item
how do i repair this
by
Add a comment
Most Helpful Answer
@dimbie could be the backlight. turn your camera on in a dark room, use a flashlight and angle it against the LCD screen. See if you can make out anything i.e. Menu etc. After that check the power on the backlight connector FP9004 with a multimeter and see what you get. The backlight is a separate item as shown on here Let us know.
Update (06/12/2017)
See if the Initial Settings Menu works for you
Score 3
6 Comments:
Ok thank you for you reply
I shall try this today
All the rest of the buttons work on this camera but like I said
Replaced with a new screen but still black
Hopefully I can see menu
Would a factory reset help
I also have a Panasonic lumix tz61 with a system focus error
Which might be a little tricky for me to do
Kind regards
by
@dimbie, factory reset would not resolve this if it is a failed backlight.
by
If the failed back light had no voltage going through it I could understand
But there is voltage 2.4volts
I just wondered if the LCD had been turned off by accident
Or the lighting settings we're turned off
Just wanted to know if there is a factory reset on the camera
Was even prepared to guess in the black screen mode by counting
How many beeps to reach the factory reset setting
But I am unable to find the reset
Do you have any other solutions
Thank for your time and help
Kind regards
by
Since you have power to the backlight, I am assuming on the connector I pointed out, your backlight should be working. It does sound more like a backlight failure. Let me see if I can find anything about a reset.
by
I can understand your point
Even though the voltage is reaching to the connector
Maybe it is the wire not sure
Maybe it was not the screen in the first place just the back light wire
But because I brought a new screen I have not brought a new back light wire
But the back light wire is quite robust tough in our words
So this is why I have not brought one
It is annoying I would like to find out what's going wrong with this camera
I have fixed many camera's in my time and binoculars
But this is the first time a have tried with a digital camera
Kind regards
by
Show 1 more comment
Add a comment
Hi Every body,
I have exactly the same problem. I bought a new lcd screen with backlight but it’s the same.
In certain condition I can see the screen without the backlight but it’s difficult, I’m really interesting by a solution because I can’t use anymore my camera like this.
Kind regards
Add a comment
Hi there
I have sold many cameras on eBay
User name jakejim
My help to you would be to buy a backlight wire for your Panasonic camera
I managed to take this camera completely apart to fix a lens problem
Which took me a while due to the amount of screws
This camera has two wires on the back screen
Hope this helps your question
If you are still stuck then take a visit to my eBay page
I may have another camera on there for you
Kind regards
Add a comment
The LCD monitor went black on my Panasonic DMC-FX200. I could still see images through the viewfinder. After many days, I realized I had inadvertently pressed the EVF/LED button. By pressing that button again, now works.
Add a comment
Add your answer
Uncle burt will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 48
All Time: 1,915
