will fill and drain but not wash
I select cycle machine fills then nothing happens clock counts down and at the end it drains,no wash no spin on all cycles
Bernard, You did not state your machines make and model#, so I will post some what generic answer. If you hear the motor running, probable problem with the drive coupling or belt, rotor/stator assy.,faulty transmission. If you do not hear the motor running(could be a loose connection/bad wire/plug/motor control board/ or possibly faulty motor.Find below a few links that may help diagnose your washers issue. (UPDATE): Now that I know INDESIT IWD7145 washing machine, added 2 more links below 4th link is hopefully a free download for service manual and 5th link is for user manual. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=wUSmUSWW...
https://www.repairclinic.com/RepairHelp/...
https://www.hometips.com/repair-fix/wash...
INDESIT IWD7145 7kg washing machine
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 18
All Time: 1,296
