Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
306 Questions View all
Hard drive swap not recognized
Replaced my Seagate 500 GB with the WD 1 TB, and the drive doesn't read. Get the ? mark. The OS was preloaded using an external HD case. Put back the 1TB in the case, it reads but it doesn't read the ITB internally. Is it that the drive isn't compatible? HELP
Comments:
can you boot the os on the 1Tb on usb?
How did you preaload the os on the drive?
by
Add a comment
1 Answer
Chosen Solution
Most likely is that the drive was not formatted correctly to GUID and Mac OS X extended. A mac will boot from an external disk that say is formatted FAT, but will not do it internally. Also, the hard drives in the 2011 had Apple priority heat sensors. Changing brands of hard drives will cause run away fan issues. OWC has addressed this issue with this fix:
OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade
https://eshop.macsales.com/item/OWC/DIDI...
Score 2
Add a comment
Add your answer
Damion Mitchell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 51
