The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
196 Questions View all
The battery of an ipad air drains quickly
The battery of the iPad air drains quickly. Have replace the battery twice and it's still not working. Please I need solution
Add a comment
Chosen Solution
Several things can cause Battery Drain issues. You will need to isolate some variables in order to get a better understanding of what is wrong. The problem could be a bad replacement battery, excessive current draw from on of the modular components (camera, button, screen) or it could be a problem on the logic board itself.
Here are some things to try:
  • It could be a bad replacement battery; there are lots of cheap batteries on the market.
    1. Try replacing with a known-good battery or order a good one from here.
  • You could have excessive current draw from one of the modular components; for example, the backlight, a camera or a sensor. You may notice a hot spot on the phone or screen.
    1. Fully charge the battery first.
    2. Disconnect the battery, then disconnect the flexes for the screen assembly, buttons and cameras, leaving only the Lightning Dock connected to the logic board (follow this guide). When you are done, re-connect the battery.
    3. Go back after an hour or more and test the condition of the battery. You will need to download either coconutBattery (Mac) or 3uTools (Windows) to see the battery condition.
  • You may have a damaged logic board. This will require a micro-soldering repair and is not DIY. Drops, bends, water damage or using poor quality charging bricks and cables, can cause this.
iPad Air and iPad 5 Battery Image
Product
$44.99
Score 3
Comments:
OK will give it a try
by
Add a comment
Hello, for the first im sorry for my English.
I replace battery on my iPad Air 2. The new battery drains also very quick, i check my ipad for hot spots and it is in the near of screen connector. What can i do now?
Add a comment
Add your answer
idowu amoo will be eternally grateful.
Past 24 Hours: 14
Past 7 Days: 80
Past 30 Days: 455
All Time: 1,935
