Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2686 Questions View all
Replaced flex cabl, everything works except volume up down
Hi, after replacing volime flash power flex cable, i have full control of everything except up down volume control. Physical up down switches are clickable but do nothing. Earphone volume switches do nothing too. Any idea? Thanks
Add a comment
1 Answer
Chosen Solution
I would go back and double check my work just to be certain. Things to look for would be tears, even partial ones, of the actual flex cable. There are tiny conductors running through the flex that can be easily damaged. I would also inspect the connector, both on the flex and on the logic board. They can be mis-aligned and even damaged if not inserted properly.
Score 3
Add a comment
Add your answer
Wanjin Kim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 38
