Why, after replacing inlet valve, does machine continuously fill?
Machine stopped filling with cold but would still fill with hot. No problem with water flow, good pressure from hose. Replaced inlet valve with correct part. Now, upon testing after replacement, water fills into machine upon switching power on (no settings selected, just power on). Can you please help me diagnose what is wrong now? Thank you.
Add a comment
1 Answer
Chosen Solution
Well, I've looked at this question several times and you did the right things to fix it. I would check the wiring to the inlet value to see if got reversed and the hot side is in the open position.
Score 2
Add a comment
Add your answer
Cheree Palmisano will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 107
