não liga acho que o zoom travou
minha máquina não liga mais. Acho que quando foi fechar o zoom ela travou. o que faço?
vc já drenou toda bateria?
vc entende ingles? se nao me avise que faço a tradução
Device won't power on
The camera does not turn on after pressing the power button.
Drained/Bad Battery
If your camera won't turn on after pushing the power button, try charging the battery. After charging the battery for a couple of hours, put it back in the camera and try turning it on again. If it still does not turn on, the battery needs to be replaced.
You can refer to the Battery Replacement Guide for instructions on removing the battery.
Broken Power Button
Your power button could be broken or the connection can be dirty. Clean under the button and its connections and try again. If this does not work, the button may have to be replaced.
Camera won't zoom
Displaced Lens
If your camera fails to zoom in/out then it's most likely due to displacement of the lens position. To check if this is the case, put the camera on its back with the lens facing up and look around the perimeter to see if there's any displacement of the lens.
If it is displaced, power the camera off and gently press gently on the lens on the side where the gap is the largest. You should hear is pop back into place. Then try powering the camera back on.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 969
2 Comments
friend, I think that if the problem was it zoom in the camerda would call but it would not give an image or an error would appear, like error in the objective `` or something semalhante
by sr.hardwaremann
Have you ever knocked her out recently?
by sr.hardwaremann
