Trackpad totally dead, any ideas why.
Hi Guys,
I've got a A1398, MacBook Pro 15" 2.2 GHz Core i7 - Mid 2014 system with 2 issues: a bad battery and a totally disabled trackpad.
I've tried all possible troubleshooting and diagnosing I could with no luck.
I ordered battery and new trackpad and swapped them both, but the trackpad still not working.
All the settings inside the computer checked. In the end, I took a backup and re-installed the OS, but the problem remains!
Can anybody help me with this issue?
Update (06/05/2017)
4 Comments
The cable looks clean and I don't see any damage. Even still this cable is likely the problem. You'll need to see if a replacement fixes things.
by Dan
Ok, actually I got a trackpad without cable. I don't have any one to test with. I will se if I can find one. So you thing this is not a motherboard issue?
by MKA
Don't think it's a logic board issue.
The cable is not passive (see the chips on it) I suspect this is the issue you're facing here a burnt chip on the cable.
by Dan
Hi,
Thank you for the notes and the help. The TP cable changeed and the macbook ok now.
by MKA
