2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
119 Questions View all
Trackpad totally dead, any ideas why.
Hi Guys,
I've got a A1398, MacBook Pro 15" 2.2 GHz Core i7 - Mid 2014 system with 2 issues: a bad battery and a totally disabled trackpad.
I've tried all possible troubleshooting and diagnosing I could with no luck.
I ordered battery and new trackpad and swapped them both, but the trackpad still not working.
All the settings inside the computer checked. In the end, I took a backup and re-installed the OS, but the problem remains!
Can anybody help me with this issue?
Update (06/05/2017)
Score 1
Comments:
The cable looks clean and I don't see any damage. Even still this cable is likely the problem. You'll need to see if a replacement fixes things.
by
Ok, actually I got a trackpad without cable. I don't have any one to test with. I will se if I can find one. So you thing this is not a motherboard issue?
by
Don't think it's a logic board issue.
The cable is not passive (see the chips on it) I suspect this is the issue you're facing here a burnt chip on the cable.
by
Hi,
Thank you for the notes and the help. The TP cable changeed and the macbook ok now.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Carefully disconnect the trackpad ribbon cable and take a set of clear pictures of the connector ends (both the ribbon & logic board) and post them here for us to see. It sounds like you have a damaged connector.
Score 2
Add a comment
Add your answer
MKA will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 193
