when my washer is done I have to turn it to spin and drain
Washing machine aint spinning clothes rite or agatating it seams like
Please give us your exact model number to get you to the correct parts.
Cause 1
Agitator Repair Kit
If the washer won't agitate, replacing the agitator repair kit may solve the problem. The kit contains the agitator components that are most likely to wear out and/or fail. If any of the parts are worn out, stripped, or damaged, replace the kit.
Cause 2
Drive Block or Bell
The drive block connects the washer transmission to the agitator. If the drive block is worn out, the transmission shaft will still move back and forth, but the agitator will only move slightly or will not move at all. Inspect the drive block for damage. If the drive block is worn out, stripped, or damaged, replace it.
Cause 3
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
How much is the adgitater kit
Never mind about the agitator. Change the timer. See if your can get it here: https://www.searspartsdirect.com/repair-...
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 131
4 Comments
Charlie Billue, Do you mean you have to manually turn the inner drum to get it to start spinning or are you saying that you have to turn the timer/dial to advance the cycle to spin cycle. This info. may help in answering your question.
by L Pfaff
I missed that, Thanks
by mayer
The timer dial
by Charlie Billue
Model w10420985
by Charlie Billue
