There are several types of PowerBook G4 Aluminum models.
879 Questions View all
G4 got rained on, dim display, repairable?
My 12" PowerBook g4 got wet from a leaky roof while the computer was in sleep mode. It will boot and I can log in, however, the display is very, very, very dim. Is there an easy fix that's not too expensive?
Add a comment
1 Answer
Chosen Solution
Hook the unit to an external monitor and see if you have normal video. If you do the logic board if probably good but you need to check the cable and connections to the LCD. If those are good you may need a replacement LCD. I am including a link so you can identify your unit and select the needed guides for disassembly and repair.
PowerBook
Score 1
Add a comment
Add your answer
David Johnson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 606
