The Sony GTK-XB5 is a high powered home audio system with Bluetooth that was released in 2016. This audio system is available in black, red, and blue.
17 Questions View all
Is it possible to add a battery
is it possible to add a battery?
Score 4
1 Comment
There is now the XB60 and XB90 with in built battery
by
Add a comment
Most Helpful Answer
becki2000seb besides all the sarcasm here is a short answer. No. The power requirements for your Sony GTK-XB5 are to large for a battery.
Score 3
1 Comment:
Apologies if it was taken as a sarcastic answer. I am used to carrying around external batteries. They even make them for laptops. A first generation HyperJuice was a literal brick.
https://www.hypershop.com/products/hyper...
by
Add a comment
The power consumption of your battery is 30w.
You need something of massive capacity, something like this:
https://www.amazon.com/Portable-Generato...
Score 2
3 Comments:
I don't know why this is funny, but it is.
by
True. I wish I could put an inbuilt battery some how
by
some bike battery could work?
by
Add a comment
I like reviving olde threads, especially ones with no decent answer! I found lithium scooter battery packs with built in BMS charging circuits integrated on Ebay. Wire in a charger for when the thing’s plugged in and you’re solid, long as you can also convert the electricity inside to amp the board, also :)
Score 1
Add a comment
I used a 36 volt 2.6Ah battery for mine after the power supply in it die and it works great.
1 Comment:
I use a 36 volt Ryobi power tool battery because the power supply in it died.
by
Add a comment
Add your answer
becki2000seb will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 31
All Time: 8,664
