No signal when battery connector bracket
I have repaired numerous iPhone until now, but this problem occurred the first time. After replacing the screen everything worked fine, except it did not get any reception. It only said "Searching...". So after some research and trying different fixes that did not help I removed the battery connector bracket (this thing: iPhone 6 Battery Connector Bracket). And voilà it worked again. After replacing the bracket it dropped signal again though. I did some testing by removing and reinstalling again and by now the signal seems stable with the bracket installed. I couldn't find anything in Google about this issue. So I just want to make sure that when I had the phone back to it's owner it will not drop signal in a week or so. Has this happened to anyone else and hows of a fix for this? Would be highly thankful!!
7 Comments
There's an antenna cable that plugs near the battery connector. Did you check if that was loose?
by Ben
Yes I did, and it is fixed. You me the small round one, right?
by tbgulli
Tell your client about the issue and if it occurs, bring it in and you will fix it for free.
by Cameron
Yes, that's I thought, too. I let it sit for a while to see if it's a permanent fix, at least for the time I still have it, but unfortunately, after some time it lost signal again. So I found out when I remove the left screw of the bracket it gets signal again. But then I don't really just want to leave it out since the battery connector sits underneath it... this is really weird.
by tbgulli
Try not making the screw so tight. It might be putting strain on something. There could be a damaged trace that gets broken with the screw is in due to pressure.
by Cameron
Show 2 more comments
