How do I fix this Grey bar in middle of screen Samsung SF351
Is this fixable and what should i try to fix it
Update (06/01/2017)
Here a picture of the problem thanks
JokingChris 101 looks like a failed TAB binding on the LCD panel. You can try and open the monitor and see if you can apply pressure on the ribbon cable that goes from the LCD driver boards to the actual LCD panel. If that lines changes you know it is the TAB that has failed. Always make sure that all ribbon cables are properly seated and that there is no corrosion inside the connectors.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 730
2 Comments
Is it worth buying it for $25 and trying to fix it ?
by JokingChris 101
JokingChris 101 I would:-) but it is personal preference. I'd take the challenge
by oldturkey03
