Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
My phone works but it shows nothing on it.
my phone was black out after an app was crashed.
phone worked but only screen was black.
i did restore it on itunes but screen was still black.
i thought screen is wrong so i replaced it.
but it doesn't show anything on it.
even the screen i replaced from my phone worked well on other iphone6 when i assembled it to other iphone 6.
i don't think it's screen problems.
is motherboard problem?
but phone still works and when i restored it on itunes, i succeeded it.
2 Comments
If you shine a flashlight on the screen, can you see a faint image?
by
yes. i can. i can barely see hello on screen if i do flashlight on it.
by
Add a comment
1 Answer
Chosen Solution
It appears you have a damaged backlight circuit. Did this problem coincide with a repair? If you don't disconnect the battery before removing a screen assembly, there is a risk you blow the backlight filter or more.
This requires a micro-soldering repair and is not DIY. I would recommend that you find a reputable shop that specializes in micro-soldering repair.
Score 2
2 Comments:
No, it happened while i was using my phone before i replaced screen.
by
i thought screen is out of order. that's why i tried to replace it.
by
Add a comment
Add your answer
Min will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 105
