Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
132 Questions View all
Help! Debris stuck in Digital Crown!
Hello iFixit! I need a bit of help here because I cleaned my Apple Watch Sport 2 With a alcohol prep pad, and some of the cloth is now stuck inside the digital crown, making it hard to turn on occasion. My nearest Apple Store is 2 hours away and I have all the tools to DIY it. What should I do?
Score 2
1 Comment
I would also like if it could be done without opening it as I like my waterproofing seals!
by
Add a comment
Chosen Solution
@reedcrosby,Reed, You may have to get yourself a cheap dollar store magnifier/glasses to aid in seeing if fibers are accessible to dislodge with a small pin/compressed air(should work). If not then you may have to partially disassemble watch to get at debri. Link below shows how to disassemble, if need be. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Apple Watch Series 2 Teardown
Score 3
3 Comments:
Thank you! I never thought of that...
by
@reedcrosby, Reed, Welcome, thanks for replying back and good luck with your Apple watch.
by
Thanks for the luck, I might need it!
by
Add a comment
Try getting some tweezers and just slowly getting rid of all the fibers, they should eventually come out.
Score 1
1 Comment:
I would, but the issue is I cannot see them but I can feel the resistance from them.
by
Add a comment
Add your answer
Reed Crosby will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 35
All Time: 2,907
