Keyboard doesn't respond after pressing Caps Lock.
Keyboard works normally until pressing the Caps Lock button. Hitting Caps Lock will make the keyboard unresponsive, you won't be able to type anything after. Can't even open up on-screen keyboard to turn off Caps Lock since it (on-screen keyboard) will hang on startup. Right now, it looks like restarting is the only way to bring back the keyboard.
Really confused what the problem is. And my Google searches aren't pulling up this specific problem.
I should add that ONE key does respond after pressing the Caps Lock key: the Fn or Function key types the number one (1.) Aside from that, nothing else works.
And it looks like opening the on-screen keyboard and turning on Caps Lock on it works normally. No keyboard hangups. No issues with turning on/off Caps Lock.
Problem is when Caps Lock key is actually turned ON using the keyboard. That's when everything stops responding. Even the on-screen keyboard stops responding though it's working beforehand.
Update (08/19/2020)
It looks like there are other people who run into the same problem. For the newcomers (welcome to the club) and for the sake of visibility, here are possible solutions compiled from other messages in this thread:
A. Disable the Caps Lock key using a reputable keyboard software found online.
B. Disconnect all keyboard connections (and maybe all other connections as well) and put it back together.
C. Replace the laptop keyboard.
As I am inexperienced in opening up laptops, I went with option A. But I would suggest option B if you know how to. Another user has experienced the same problem and reconnecting all the, well, connections is what solved it for him.
Good luck!
1 Comment
Hi!
My Lenovo 510 yoga started having the same problem right now. How did you fix it?
by Demetrio Bezerra
