The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
248 Questions View all
...As long as the volume up key + home key + power key does not work
As long as the volume up key + home key + Power key does not press enter simultaneously?
aside after connect charger with phone and the volume up key + home key + Power key
press enter simultaneously a msg appear " A custom OS can cause critical problem in phone and installed applications.
if you want to download a custom OS press the volume up key.
otherwise, press the volume down key to cancel.
i am trying to press volume up key but nothing happen...
Add a comment
1 Answer
Sounds like your Vol Up key is stuck. Does it click when you press it? Does the phone boot when you press just the power button?
1 Comment:
Volume down key would be at fault as well as it requires holding volume down to boot Odin download mode.
by
Add a comment
Add your answer
Amit Mishra will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 297
